Skip to content
Mapping APIs: Bringing Your Spatial Data into Bing, OpenLayers, and Google
Stewart Harper
June 22, 20115 min
A map is often used to display overlays conveying information to users. How you go about getting your data onto the map varies depending upon the mapping API. In this...
A map is often used to display overlays conveying information to users. How you go about getting your data onto the map varies depending upon the mapping API. In this post we will explore how you can get your vector data on the map (points, lines and polygons) using the mapping APIs from Bing, Google, and OpenLayers.
I was inspired to write this post after recently building a demo where I worked with several mapping APIs. This post will talk about are the formats that are natively supported by three of these mapping APIs. However, it’s worth noting that you can get pretty much any web-based format onto a map by using FME Server – or by parsing the data, looping through it and using the mapping API’s standard calls to create geometry and add it to the map.
Bing MapsBing
Native Formats Supported:
As you will see, GeoRSS and KML are standard across all platforms. The one that stands out with Bing is the ability to display data directly from your spatially enabled SQL Server 2008 database (available in both the Silverlight and Ajax frameworks). I have never actually used the SQL Server data connector so I would be interested to get some feedback from anyone that has. Having played around with the demo and having looked at the code, this looks like it would definitely be worth a look if you already have a SQL Server database setup and running.
Performing the Overlay:
Gotchas:
Overlaying the GeoRSS/KML is trivial with only a few lines of code. The problem I have is that Bing Maps gives every feature a pushpin icon irrespective of the type. For example, if you import a polygon it will put a push pin in the middle of the polygon and it is the same for the polyline. There is a workaround detailed here, but why not enable me to configure the visibility of the push pins through the API?
Pushpins in Bing maps
Pushpins which are auto-generated for every geometry type.
Google MapsGoogle
Gotchas:
The main thing which caught me out when using these services relates to the google.maps.KmlLayer (or GGeoXML in Maps v2.0) caching the data. For example, if you have a KML/GeoRSS file on the server and change the content, there is the potential that the changes will not be reflected in the client application. The way to ensure this doesn’t happen is to append a timestamp at the end of every request as a parameter.
varmyKml = “http://mypublichost/roads.kml”;
varkmlObj = new google.maps.KmlLayer(myKml + ‘? dummy=’ + (new Date()).getTime());
The trouble is that the caching is there for a reason, so ideally you would only append the timestamp if you knew the data had changed. Easier said than done…
The other limitation of rendering using the google.maps.KmlLayer (or GGeoXML in Maps v2.0) is that the URL has to be public. There is however an alternative to using Google’s service, you can do it client-side. I have used this great little open source library from Lance Alan Dyas on several occasions to render my KML, and it works perfectly. It has the added advantage of giving you the freedom to step through and tweak the code which does the parsing; it also extends your format support to:
  • GPX
  • WFS
  • GML
OpenLayersOpenLayers
As you would expect, OpenLayers is the king of format support. Here are the major formats that are supported (check the API for a full list):
  • ArcIMS
  • ArcGIS Rest
  • GML
  • GeoJSON
  • GeoRSS
  • GPX
  • KML
  • OSM
  • WFS/WMS
  • WKT
  • XML
Gotchas:
While the documentation and examples related to OpenLayers are excellent, I have found the community content to be not quite as extensive compared to Google/Bing. When I have a problem with Google/Bing, 9 times out of 10 I can find a solution on a forum somewhere. When working with OpenLayers I have hit several issues that have taken be a good amount of time to figure out. Having said that OpenLayers is a fantastic project, so give it a try – post your problem and contribute to the OpenLayers community.
Which mapping API have you worked with? Do you have any gotchas that you would like to share?
Safe product icons
Reach out and get started with FME today
